This car started as a California car. I brought it to Arizona a few years ago so it would be appropriate to see it go back to CA. You might be familiar with it from it's yearly trips out to the San Diego tour. Here is your chance to get a regionally competitive stock class car that you can run at the next event with no work. Or for a little more work there is always STR with springs, Ground Control sleeves and wheels.
Silver 1999 Miata "Sport", with the Hard S suspension AC and power steering
37K miles, only driven on Sundays
Garage kept with the usual Mobile 1 and 91 its whole life
Matching Mazda hard top
New soft top 3 years ago, only seen about 20 days in the sun with the garage and the hard top
2 sets of factory wheels, weight is 13lbs on those
1 set of ASA BBS look wheels, 16x7, tires have about 1K miles on them
Off the shelf Koni yellows with about 1K miles on them
Borla exhaust
DeLan hidden hitch with receiver and wired for brake lights
Racing Beat 1 inch front sway bar
Racing Beat front sway bar end links
Racing Beat front sway bar reinforcement blocks
Machined collars for front sway bar to prevent walking
Hawk HPS front brake pads with about 10K miles
Hawk HP+ rear brake pads with about 10K miles
Factory Service Manual included, an actual book, not a burned CD from eBay
Reese Transporter 750 enclosed trailer, tires are about 5 years old with 20K miles on them, new tires are about $30 at Walmart
New wheel bearings in the trailer about 1K miles ago
