I went through the entry list today and corrected any number that did not fit the numbering system that is being used for this event. Please review your entry and see that your information is correct as the work and run order are now being finalized. Questions can be posted and answered on this thread.
Here are the numbering rules for this event:
A ‘National Style’ numbering system will be used for this event which is choosing any number 1-99 for a first driver and adding 100 to the number for a second driver. Cars without a co-driver will use 1-99 only. Numbers are available on a first come first served basis per class (e.g. 99 in AS is seen as different from 99 in CSP). As always, easy to read numbers and class letters are required on the car.
If you are a local Cal Club points card holders, do not use your SoCal Solo points card number for this event unless it happens to fit within the "National Style" numbering system described above. If you have a numbered placard with a number higher than 99, you can still choose a number in the preferred range (1-99) and using tape to cover unneeded numbers on your existing placard. Unless otherwise requested, those who normally compete locally in a Pax class will be reclassified for local points and scoring after the event. Like all national events, the run order will be created based on registrations and will not be the usual local run order rotation.
Divisional Numbers Have Been Corrected
