We've been getting into the mid 240 oil temperature. Bryan P. says that if you aren't getting into the 260's you aren't pushing it enough!
Any Tips on Flushing a Z06 cooling system
GM specifies a specific replacement coolant ... what about adding some Redline Water Wetter ?
				Arthur Grant
 - Car#: 314
Re: Any Tips on Flushing a Z06 cooling system
You can add water wetter to anything. Works great in my vette.
						- Thomas Barrett
 - Car#: 519
I understand a Vette runs cooler with only water and water wetter than with coolant. Also if you ever spring a leak the clean up is a lot easier.
I never run coolant and no problems.
Tom Barrett
Corvette Specialty C6
Life is like a race, the best times win!
Brian reminded me that he put in a 160 degree thermostat, but used GM specific coolant. We'll do a flush and fill with water and Water Wetter ... and clean the radiator. It was easy to put in a new Miata radiator ... I'll check our shop manual on removing the Z06 radiator for a thorough cleaning.
Any opinions on using regular tap water vs distilled water vs filtered water from my Brita water filter system?
Use distilled. The water in L.A. is very hard and will deposit lime in your cooling system (not conducive to flow or heat transfer).  A Brita fiber & carbon filter won't remove the minerals from the water.  If you have a reverse-osmosis filter then you could use that water.
Absolutely use distilled water.
