Karen & Mako's Further Flat Bedding Adventures
We were on our way over the Rogers Pass here in BC Canada to visit Karen's brother and sister when the Suby ended up on a flat bed again.
- FlatBedded.jpg (109.51 KiB) Viewed 9113 times
Re: Karen & Mako's Further Flat Bedding Adventures
Holy cow!! What now?
- Pete Loney
- Car#: 777
.....must get rid of problem subies... time to go....
More detail plz...
More detail plz...
Part 2
Hmmm....
I'm guessing not a mechanical issue...
The look of those tracks in the wet... is that a bit of snow on the ground?
Did you end up off the road like the other car in the ditch?
No snow ... we were carefully monitoring the exterior temperature as we came down from the mountain, and it was in the mid '50's
Greg Peng
- Car#: 908
"PeaSize" hail?
So, what happened?
David Barrish
- Car#: 58
It's called "corn snow". Very slippery stuff.
P3 ... I'm photographing the car in front of us, trying out some high iso settings in the gathering gloom. Karen has just moved into the passing lane. We never noticed the scene on the left of the photo.
CLICK on photo to see it in it's entirety
- 1stOffShot.jpg (281.06 KiB) Viewed 8962 times
Sarah S ... with the Maxima she just inherited from her grandma.
- Sarah1.jpg (253.66 KiB) Viewed 8959 times
Looks like she's taking a driver to the thing...maybe a 3 woodMako Koiwai wrote:P3 ... I'm photographing the car in front of us, trying out some high iso settings in the gathering gloom. Karen has just moved into the passing lane. We never noticed the scene on the left of the photo.
Omg! I feel so dumb, didn't know that this can be done, been scrolling up and down on attached pictures forever ....CLICK on photo to see it in it's entirety
you are so fail at foruming..T. Osifeso wrote:Omg! I feel so dumb, didn't know that this can be done, been scrolling up and down on attached pictures forever ....CLICK on photo to see it in it's entirety
Ha ... I didn't intuitively know about Clicking on photos presented that way at first either.
how else are you suppose to get the p0rn links if you don't try clicking on everything?!.. jeez!!Mako Koiwai wrote:Ha ... I didn't intuitively know about Clicking on photos presented that way at first either.
P4 ... It wasn't THAT tragic ... a bush got mowed down. Karen's brother Don on the right.
- NotTHATbad.jpg (113.15 KiB) Viewed 8898 times
Not fair, you added "P2" after my snow guess.
so... the Mounty shot out your tire when you attempted to leave the seen thinking you caused it?
I guessed Snow, someone else guessed Hail (with your added "P2", the only white stuff left would be freezing rain, but the first evidence of that would be in the trees and other plant material, and there's no evidence of that.
on a side note - 50 degrees out side? That in and of it's self does not mean it's not snow. One it dosen't need to be freezing at ground level, just in the clouds, two it could be melting at this point from a colder overnight dusting.
Beyond the frozen moisture on the ground, vs. just wet surface, that were evidently not guessing the correct "name" of.... and you did not respond to my comment about an accident vs. mechanical....
Obviously were not guessing the cause of your tow it from what you've provided in the way of photos.
P5 ... this surface looked just like El Toro ?!
- At ElToro.jpg (162.83 KiB) Viewed 8858 times
Intermission ... Rush Hour in the Rockies
- RockyRushHour.jpg (192.39 KiB) Viewed 8855 times
P6: If you come to the AX in Calgary this weekend ... we can show you how to control a slide ... oh ...
- IfAXthen.jpg (174.95 KiB) Viewed 8846 times
Greg Peng
- Car#: 908
The Subaru! What happened to the Subaru?! :mrt: :unimpressed:
- Christine Grice
- Car#: 17
Judging by the first pic, they probably backed it into the ditch (no upper front end damage) or ended up busting the oil pan on a rock when they slid off the road. The story was taking too long, so I lost intrest a long time ago...Greg Peng wrote:The Subaru! What happened to the Subaru?! :mrt: :unimpressed:
Bingo ... note the icy marbles
