Whats the widest tire that works best on a 15X7 wheel?
- Cam Correa
- Club: Team Blew
- Car#: 306
I'm currently running a 195 Re-01 on my 15 x 7 wheels but was considering going wider.
What have you guys found to work best while still fitting properly on the rim?
Would going to a 225 be too much for the 7 incher?
Will the tire bulge too much at the side walls?
If so would I get better traction using a narrower tire like a 195 that is probably more along what is normal for such a rim?
I've heard, that I could probably go as wide as a 245 on these rims if wanted to?
Just figured you guys would be the best to ask vs most other sites I visit.
Thanks.
Thanks.
http://www.Class3Racing.com" onclick="window.open(this.href);return false;
http://www.TheWebWheeler.com" onclick="window.open(this.href);return false;
Re: Whats the widest tire that works best on a 15X7 wheel?
In you particular situation, I would suggest 195/50-15 Toyo R1R. Most of the ST and STS competitors are using 195/50-15s on 7.5" wheels.
And there is actually a drop off in grip with the 205 Toyo R1R
... but I would vote for the Hankook RS3 in 225/45/15: http://www.tirerack.com/tires/tires.jsp ... &tab=Sizes" onclick="window.open(this.href);return false;
Please buy from The Tire Rack and use the link at the bottom of the page, as we get a kick back
Agreed.Sebastian Rios wrote:In you particular situation, I would suggest 195/50-15 Toyo R1R. Most of the ST and STS competitors are using 195/50-15s on 7.5" wheels.
- Cam Correa
- Club: Team Blew
- Car#: 306
& I was eyeing the Toyo R1r's actually.
& you saying the Toyo's drop off at 225 & yet the Hankooks don't?
No, that's not what I said. The Hankooks will last you longer, especially in the summer
My vote is for the 195 Toyo which will last plenty long. Those things are some sort of magic!
- Cam Correa
- Club: Team Blew
- Car#: 306
So is there a down side to going wider than 195?
Like 225 or more?
Like 225 or more?
The National Championship winning STS Miata was on 195 Toyos.
- Eric Clements
275/35/15 Hoosier A6 works on a 7" wheel. Oh, ST, never mind..
Cam Correa wrote:So is there a down side to going wider than 195?
Like 225 or more?
The downside is that you go SLOWER. Some complicated explanations... but ultimately I see it as a nobody really knows. The closest to the 195 R1R is probably the 225 Hankook RS-3 which is a very good long lasting tire though your first run is a throwaway. I'm not sure what the Bridgestone guys run, probably a 205-50-15. All three diameters are a tiny bit different which can be a course dependent thing. But you're lucky to run in a region with a number of the fastest ST/STS guys in the country. We know what is fastest, what is close, and what the trade-offs are. And most of us have tested the heck out of the various brands, sizes, and combinations.
Copy who is fast until you get to the point that you can lead the pack and let others copy you.
Talk to Jon Lugod and Mike Heinitz.
- Car#: 314
Grassroots motorsports did a number of test with a Miata and found larger was indeed slower. I will see if I can find the article.Steve Ekstrand wrote:Cam Correa wrote:So is there a down side to going wider than 195?
Like 225 or more?
- Cam Correa
- Club: Team Blew
- Car#: 306
Very interesting thank you very much..Arthur Grant wrote:Grassroots motorsports did a number of test with a Miata and found larger was indeed slower. I will see if I can find the article.Steve Ekstrand wrote:Cam Correa wrote:So is there a down side to going wider than 195?
Like 225 or more?
What am I chopped liver?Kurt Ra wrote:Talk to Jon Lugod and Mike Heinitz.
I have driven on all the tires and sizes mentioned, in some cases mounted on 7" and 7.5" wheels.
I believe that given the facts Cam has presented, the fastest tire in an autocross setting will be the Toyo R1R 195/50-15.
Don't know about your tire knowledge, but you're definitely the goto guy for how to drive the motor home...................Sebastian Rios wrote:What am I chopped liver?Kurt Ra wrote:Talk to Jon Lugod and Mike Heinitz.![]()
[quote="Sebastian Rios"]
Better question for us skirted ST types is what tire does Shauna like?
When I said I wanted to run less then 225 on track, I got laughed at
Interesting, AX'ers have gone away from more rubber is better.
We haven't. It's just that the 195 Toyo > *Mako to wrote: Interesting, AX'ers have gone away from more rubber is better.
Street tires just simply need as much sidewall support as it can. So a 195 on a 7.5 is ideal for us lighter cars on those toyos. Each tire is different and I believe sidewall is key. Stuffing a 225 on a 7 is doable, you'll just need to run higher tire pressures to keep the tire happy. For autocross I think this is important since we transition a lot more than any road course can offer. What works for autocross doesn't necessarily work for track.
Not chopped liver, but possibly ground beef.Sebastian Rios wrote:What am I chopped liver?Kurt Ra wrote:Talk to Jon Lugod and Mike Heinitz.![]()
