1997--(Model -- VIN please send requst)
http://www.brakefade.com/files/pics/Aut ... 011/album/" onclick="window.open(this.href);return false;
please email to: granthe@pacbell.net
1.8l
205k
Red on black
New softtop with glass
P/S and A/C
MOTOR
Just replaced with 97 m-edtion (see links) compression 180, 180, 180, 180
New Mazda Comp Motor Mounts
New clutch kit (disk, cover, surface flywheel)
New Timing Belt, Valve Cover Gasket, 2 Cam Seals, Front Crank Seal,
Tension Spring, Tensioner Pulley, Idler Pulley, Water Pump, 2 OEM Water Pump Gaskets,
Water Pipe O-Ring, Alternator Belt, and Power Steering / Air Conditioner Belts.
New Oil Pan gasket
New Rear main seal
New PCV Valve
New ALL hoses replaced
New CAS O-ring replaced
Oil change and filter
New Exhaust Gaskets and Studs/Nuts
TRANS
New inner/outer rubber boots
New gear oil just replaced
Rear trans seal replaced
New slave clydiner
949 racing long steel braid clutch line
BRAKES
New front rotors and pads
Complete system fliuld fulsh
MISC
Tires less than 5k on 14" Dasiy wheels
New battery 12/10
97 Miata in OC $3995
