I have a Spec Miata that I'm considering running in an autocross event. What class would it run in and what other cars are in that class?
How would old shaved Toyo RA-1's work? On the track it seems like they take some time to get up to temp and get sticky.
Brian
Spec Miata class?
Re: Spec Miata class?
I believe SM cars are legal for CSP.
CSP is full of highly modified Miatas.
Old, shaved RA-1's will probably suck, and even if they were fresh, they would not be competitive.
Still, the point would be to have fun, so you should come anyway
It's actually DSP, not CSP. It's a strange fit since miata's are mostly in CSP, but the SM are put in DSP because they have no chance of keeping up with a mildly prepared CSP miata.
You have to run it in by SM rules with the exception of any DOT tires and rims.
- Steve Coe
- Car#: 75
Cars eligible for the current Spec Miata rules are permitted to compete
in class D Street Prepared, with the additional allowance that they may
use any size of any tire which meets the requirements of 15.3 and fits
on the Spec Miata allowed wheels and within the allowed bodywork.
Spec Miata cars in DSP may not intermix use of the Spec Miata and
Street Prepared allowances. The competitor is responsible for being
in possession of the Spec Miata rules and for proving that his/her car
conforms to the rules.
page 91
http://www.scca.com/documents/2011%20Te ... 0Rules.pdf" onclick="window.open(this.href);return false;
page 91
Of course locally you could run in our CPM class, a run-what-you-brung class, on R tires.
I drove Christian Austian's SM Miata on a AX course ... it felt surprisingly like a heavy pig. I guess the engine is peaky where it needs to be torque tuned. And yes, RA's would need a VERY Hot day to be at all useable in AX.
One of these days I'll probably try my ITA Miata in an AX
David Barrish
- Car#: 58
Brian,
Having driven on RA-1's that were cast off's from a spec7 I would encourage you to come out and drive them until they turn white.
I found that they got better with time.
David Barrish
David Barrish
Not CPM. That is combined Preps and Mods. Mako meant CSM. California Street Mod.
Brian Linn
Thanks for all of the responses.
I do have some Hoosier slick/radials mounted up of 15" dia wheels, so it sounds like I could use them. The compound is probably harder than what is desirable for autocross, but if it's just to have fun, they should be good enough.
I can remove the roof for autocross - legal for SM on the track, but the aero drag hurts at high speeds. I would guess that getting rid of the weight up high is worth more than the drag factor for autocross. What are the top & average speeds on an average solo2 course? I know I'm overthinking this, but...
The SM brake pads are probably made for too high of a temp range too....would a street pad work better?
Non-DOT slicks are not allowed in DSP, CSP or CSM, at that point you would be in DP.Brian Linn wrote:Thanks for all of the responses.
You can heat the brakes up easy enough dragging the pedal from grid to the start.
Leave that turd at home and bring the FP car.
