Co-driver wanted 4 Lincoln ProSolo/Spring Nats. & B'ville
Bill Schenker
Car#: 14
Post by Bill Schenker »
Photo by Mako, 2012
Photo by Mako, 2012
These four races are over the long Memorial Day weekend, starting Friday, May 25th through Monday, May 28th, and June 8th - 11th
The deal I'm looking for from my co-driver is this:
Co-driver drives rig there and back, I pay for gas.
Co-driver pays for 2 sets of tires. If co-driver normally uses the size the car uses, 275/35/15 A6s on his/her car, they can have the tires to keep when we're done with them. I will provide good tires for first day morning runs of the Pros, if the weather holds, and the new Hoosier Wets if the weather doesn't any other time during the events!
Any Mazda $$ ($200/first, $100/second) won by co-driver is theirs to keep; any Hoosiers won by co-driver is/are mine.
Any wear and tear or maintenance is paid by me, any damage whose cause is not determined, paid by me. Any damage directly attributable to co-driver is paid by them.
What you get: to drive one of the most fun cars out there! The car is working great (very fast times with a test motor that is 40hp & 40ft/lb. down) at local races this year (car will have strong motor back in for Lincoln) and it looks like we've figured out what's been wrong with my motors over the last 2.5 yrs.
I'll be more than happy to get you in the car at local events before Lincoln to get used to the car (hint: it goes wayyy faster through corners than you think it should and it likes to be driven loose).
Last edited by Bill Schenker on Fri Mar 30, 2012 10:18 pm, edited 2 times in total.
Kurt Williams
Car#: 219
Re: Co-driver wanted for Lincoln ProSolo/Spring Nationals
Post by Kurt Williams »
" likes to be driven loose" So you are looking for a loose co-driver ,
Does Tayla know ?
Bill Schenker
Car#: 14
Kurt Williams wrote:" likes to be driven loose" So you are looking for a loose co-driver ,
Does Tayla know ?
....And does Gina know what bad jokes you make? :)
Bill Schenker
Car#: 14
Bump.
The must be under 6" part tends to shrink the field of possible candidates. }:)
Bill Schenker
Car#: 14
Bump.
Bill Schenker
Car#: 14
Bump.
This car is on my national Solo car Top 5 of cars I'd like to drive. Great opportunity for some skinny dude.
