El Toro Site Map
El Toro Site Map
Does anyone have a site map for El Toro that can be used to design courses with, similar to the map that Roger created for Fontucky?
Re: El Toro Site Map
http://public.fotki.com/makofoto/2012-racing/misc-2012/
Check out these ... you should be able to click on a Down Arrow to the upper right of the individual files ... to download a larger original version ... which if you click on again, show larger still. I might have some more ... chx'ing
http://images38.fotki.com/v1221/filecqF ... ialSML.jpg
We use to use the West part of the "lot" ... but I'm thinking we can't any more?
btw. the runways are basically 180' wide ... between the white lines
Sweet. Thanks, Mako!
John Fendel
Car#: 23
Post by John Fendel »
Attached is a PDF file of the El Toro site that I use to draw our courses. I print it in landscape mode on 8 1/2 x 11 paper. You can blow it up to 11 x 17 for more detail. North is to the left on the map.
ET Map Master.pdf
(443.59 KiB) Downloaded 182 times
John Fendel wrote:Attached is a PDF file of the El Toro site that I use to draw our courses. I print it in landscape mode on 8 1/2 x 11 paper. You can blow it up to 11 x 17 for more detail. North is to the left on the map.
Nice. Thanks, John.
Elliot Speidell
Post by Elliot Speidell »
Gridded El Toro Template courtesy of Clint Child. I have a power point template with some design stuff that I can email anyone who wants it, board is telling me the .pptx is not allowed to attach.
EL Toro-20' Grid.pdf
(16.83 KiB) Downloaded 193 times
Elliot Speidell wrote:Gridded El Toro Template courtesy of Clint Child. I have a power point template with some design stuff that I can email anyone who wants it, board is telling me the .pptx is not allowed to attach.
Perfect! Thanks, Elliot!
