Course Setup Friday Sep 21st
First come first serve. I need (2) body workers to help setup course. This will count as your work assignment for Saturday's Practice OR Sunday's Champ event. ***NOT BOTH***. This work assignment also involves the course switchover at the end of Saturday's practice. You will need to fulfill both duties in order to be exempt from work.
1. Jeff Chodos
2. Mako Koiwai
My plan is to bring the Nationals East course onto cal speedway to let all of those who didn't go to nats to experience such a course. Of course it will deviate quite a bit but the goal is to have a national style course. Sunday will be reverse of the nat's course. This should be a very fun course and easy to layout. ;)
1. Jeff Chodos
2. Mako Koiwai
Last edited by Jonathan Lugod on Mon Sep 17, 2012 11:54 am, edited 3 times in total.
Jeff Chodos
Re: Course Setup Friday Sep 21st
I will be glad to help set up the course. I am experieced not with the SCCA but with another AX group.
Jeff Chodos
Jeff Chodos
- Michael Palero
- Car#: 18
I'll help.
Bump
I haven't heard back about my job next week, so I might able to make it. Should know on Monday
Cool ... so I'm working Tue thru Thur ... so I can help with Friday's set-up ... to count for my Sunday work assignment. Thanks!
plan to arrive at the speedway at 2PM. I work that day so i maybe a little late. I will email the course map to you guys before then. Lily and Mike K. will be around to help as well.
Please keep in mind motorhome placement when setting up start/finish/grid. Not relevant which side of the motorhome the start is on, but for Sunday the staging line needs to be a good distance past the motorhome (not next to it) and ideally angled slightly across the front. Making it easy for the timing crew to see cars without looking over their shoulder is a nice thing.
Also, placing the motorhome near the middle (grid on one side and pits on the other) makes the PA system much more effective.
Thanks for your consideration.
Rick
Rick
Jeff Chodos
See you at 2:00 on Friday.
Jeff Chodos
Jeff Chodos
I'm still stuck at work, so I'll be there a little late. I work in Santa Monica and I'll be leaving in the next 20 minutes or so. I should be there by 2:30 assuming no traffic.
~Lily
Just got off the 210...good luck with the commuteLily Liu wrote:I'm still stuck at work, so I'll be there a little late. I work in Santa Monica and I'll be leaving in the next 20 minutes or so. I should be there by 2:30 assuming no traffic.
Cones r chalked - just need outlining done. Course is pretty clean for a change
Great course, Jon! It was a blast!
