Trying to clean out my storage to finish fixing the car and get back out sometime this year X.x If you know anyone after parts, let me know. photos available upon request. too many to post here.
Coupe A-Pillar, satin black - $30
Coupe A-pillar, satin black, 1 gauge hole - $45
06 Factory Antenna - $10
Extra Dipstick - $15
2.2L windshield washer tank + pump - $30
Computer Cover - $5
Black 120mph gauge cluster - $60
Black rear floormats (like new) - $40/set
1 SS rear shock, still good - $20
2006 stock 2.2L fuel injector kit - $80
Full set of black seatbelts - both front and all 3 rear, never in wreck, very nice condition - $200 for the set, i dont want to part this out.
Brand new inner tie rods for an 06 - $60 for both.
2x oil filler caps, new o-rings, not rounded up - $10 each
Misc sensor (not sure which it is, crowd source it!) - $20
MAP sensor off a 2.2 - $20
Rear Bowtie - $5
Front Bowtie w/ nuts - $10
2x airbag lights for center console - $5 each SHIPPED.
Lightweight aluminum alternator pulley 5 rib NEW - $45
Upper radiator mounts - $20 set
Cupholder - $10
Stock 2.2L serpentine Belt - $20 shipped
2x Rear headrests. $30 each or $50 for both
GM Performance Short Ram Intake w/ box, and newish filter - $175
LSJ throttle-body +spacer (8pin) - $80
Napa Front brake pads for 2.2L 4 lug w/ ABS, like new - $30
Stock engine mount - $20
2x stock 2.2L throttle-bodies (8 pin) - $50 each
2.4L (8pin) throttle-body - $60
Front windshield rain tray - $60
L61 Valve cover - $70 (camaro synergy green atm, flatish texture)
Stock 2.2L clutch (40,000 miles mostly highway) and flywheel - $150
Lighter weight 2.2L flywheel - $75
FE5 Moog endlink set - $40
Ingall's Camber Kit - $20
2.4 Intake manifold, good gaskets, new fitting there (no leaks) - $70
2.2L intake manifold - $50
Random stock Exhaust manifold.. I think its a L61... - $50 (has new gasket to DP)
Engine mount block - $20
2x Brake Master Cyl Lines - $20
SS/SC Front swaybar w/ prothane mounts - $60
2.2L Tensioner - $20 SHIPPED
Intake Line ( i forget what its called) - $15
Tinted 3rd Light - $20
Non-Tinted 3rd Light - $20
L61 Coilpack (no plugwires) - $75
Old School GM wax and polishing clothes - $20 each, 3 for $50
Satin Black rear wing, few scrapes on bottom - $60
L61 complete cylinder head - $150
15" steel wheel set (all straight, no damage)- $100
Tons of chevy cobalt parts
Chris Hofmann
- Car#: 501
A1 Higher Graphics | Clutchmasters | CobaltNation | CrateEngineDepot | DEI | GoPro | GoPuck | PLWA | Rockwell Time | Slick Products | SpyOptics | Trackspec Motorsports | ZZPerformance
#501 Chevrolet Cobalt
Chris Hofmann
- Car#: 501
Re: Tons of chevy cobalt parts
editted with all the stuff i found in the storage unit today.....
