Helping sell this car for a friend.
I'm helping sell this car for a friend.
The car is located in the southern California Area.
#159 2014 SoCal NASA Championship winning car
$12,500 for complete ready to race package for NASA SpecMiata challenge
Solid mid pack SpecMiata. And it can be driven faster than I can drive it, so this is a great reliable car to start spec miata racing with...
Car has everything done to it that a car could have for SpecMiata
50,000 miles on original gauge cluster and engine bottom end, second owner racer car. Non-smoker.
1994 SpecMiata
• Engine
o Springfield dyno exhaust
o East St Auto pro head, 2 years of racing
o 5xRacing Adjustable Fuel Pressure set and AFR guage
o Autolite AR3935 sparkplugs
o K&N Filter element in stock box
o Custom extended length exhaust trans tunnel heat shielding
o 2 season old fuel filter
o Wizard Racing prototype radiator, better than Koyo, 2x protective screening
o Custom coolant sensor install and Autometer Guage
o Engine Water Pump, Timing Belt, and Oil Pump replaced/rebuilt this year
o Fuel Sample test port, Custom fuel pump out system
• Drivetrain
o ACT clutch
o ‘99 17 lb flywheel
o Stock 5 sp trans with only 2 seasons on it, shifts smooth
o 4.3 Torsen Differential
o Re-built 1pc axles with 1 season on.
• Suspension
o Required SpecMiata Suspension Package: Springs, Sways, Dampers
o 99 / FatCat Top Hat Kit damper setup for full travel when lowered
o Rebuilt East St Auto front hubs with extended length studs
o 949 Racing adjustable Sway bar end links
o Stock OEM Manual Steering Rack
o New tie rod ends 2014 season
• Brakes:
o XP10 front, XP8 rear, with spare brake pad sets…
o Front and Rear Caliper full rebuild, 2 seasons on calipers
o Parking brake full removal, including rear caliper internals
• Chassis
o Doors completely gutted to max legal amount
o East St Trans tunnel notch out panel
o All internal sound deadening/mastic removed for weight savings
o Custom hard top bolt down system
o CPG steering wheel quick release on adjusted and lower column
o Separate 20 amp power and accessory fuse panel
• Custom install of smallest and lightest legal battery
• Wire for Battery tender for extended storage
• Wires for cool suit install
• All Premium synthetic Royal Purple Fluids throughout
• Recently Dyno’ed Motor, available to serious buyers
• Recently Dyno’ed Bilsteins, available to serious buyers
Safety
• Fully TIG welded cage with extra diagonals and triangulation
o HIK Fabrication install of MiataCage kit
o Miata cage b-Pillar block off plates
• Chassis fully seam and opening alum taped against smoke intrusion
• 200 amp kill switch mounted on roll-bar
• Fire System, FireSense / SPA 10lb alum Bottle with 4 nozzles,
o Extra 10ft of tubing for engine bay suppression hookup.
• Alum Racing Seat, Kirkey Racing 17” width
o Custom mounting for 6 ft + driver
• Belts, 6pt good until 2017
• Window and center net
• Required front and rear tow points
Spares
• Wheels
o TR Motorsports 15x7 black racing wheels
o Kosei K1 Racing 15x7 lightweight racking wheels, powder coated black
• Tires
o 3 sets Toyo RR NASA spec competition tire, 1x brand new, 1x 2 weekends, 1x last year
• 1.6 front sway bar and mounts as required for national competition
• 1 set of dampers ready for rebuild, customer mounting hardware on fronts
• Depowered and Welded Quick Ratio Power Steering Rack, with tie rod arms
• 2x Front Rotors
• 1 set Front Calipers
• 1 set Rear calipers
• 1 left, 1 right Rear uprights for re-build
• 2x upper rear arms
• 1 rear sub-frame, measured straight
• 1 set expired belts for passenger/instructor
• 1 Cam cover, ready for paint
• 2x 5.5 gallon gas cans, 1 red, 1 purple
• 1 red door
• Stock 14” wheel with street legal tires for storage and street driving
• Multiple Fluid containers
• Complete pedal assembly for adjustment and potential mods
• Spare brake booster and reservoir
• 1 set of front spindles
• Passenger AC fan to
• Power Mirrors installed, switch included and left to hook up.
Link to the raceconnect ad
1994 SpecMaita & Spares Package, 2014 NASA Region SoCal Cham
- Bobby Beyer
Re: 1994 SpecMaita & Spares Package, 2014 NASA Region SoCal
Goodluck on the sale... I did find some humor in the posting.
Followed two lines later by...Bobby Beyer wrote:#159 2014 SoCal NASA Championship winning car
Apparently winning the SoCal NASA championship comes down to showing up... more than winning races.Bobby Beyer wrote:Solid mid pack SpecMiata.
- Bobby Beyer
Like anything else when you show up to all 12 races you have a higher chance of winning on points. Even taking that into account he does a pretty good job of keeping up.
Wilson does a pretty good job of keeping up, but his budget doesn't allow him to spend the money on his motor that the top dog guys do. He got really into Chumpcar racing so he's pursing that instead of Spec Miata. Only showing the top 14 rather than the whole field.
1 Wilson Steele Spec Miata Mazda Miata 890 80 90 100 100 70 70 75 80 90 43 46 67 68 89
2 Brett Becker Spec Miata Mazda Miata 886 90 70 70 80 90 90 75 85 85 85 65 66 65
3 Matthew Million Spec Miata Mazda Miata 620 75 85 80 80 58 62 90 90
4 Jeremy Barnes Spec Miata Mazda Miata 490 90 100 100 100 100
5 Ken Saward Spec Miata Mazda Miata 475 100 90 100 75 57 53
6 Ramon Niebla Spec Miata Mazda Miata 416 80 80 70 90 54 42
7 Garrick DeLaFuente Spec Miata Mazda Miata 372 35 35 80 69 68 85
8 Joey Jordan Spec Miata Mazda Miata 370 100 90 90 90
9 Rob Burgoon Spec Miata Mazda Miata 370 85 85 100 100
10 John Mueller Spec Miata Mazda Miata 365 85 75 46 51 75 33
11 Nova Brown Spec Miata Mazda Miata 356 85 69 75 61 66
12 Noah Grey Spec Miata 343 35 35 45 63 85 80
13 David Dodge Spec Miata Mazda Miata 330 90 100 70 70
14 Richard Mathias Spec Miata Mazda Miata 309 69 75 80 41 44
