Preliminary 6/14/15 Results
Must have been more tired than I thought after the event, thought I posted this shortly after the event was over, but I must have previewed it and not posted. :p
Preliminary results (basic penalty audit, but not inspected for errors or missing stuff) will usually be available right after the event on our live timing link http://www.tinyurl.com/solo2live.
There are missing times and classing issues in the above link that I'm aware of. Class and PAX results will be up in the Event Results area soon, ready for feedback for the stuff that's not obvious to me.
While I have your attention, a little info on pre-registering on Motorsportreg.com.
When selecting your class, there are two types of classes, the regular SCCA classes and a couple of local ones that are "heads up" racing, and INDEXED (or PAXED) classes that are groups of classes indexed together. If you are in the first group, DO NOT PUT ANYTHING IN THE "PAX" BOX WHEN REGISTERING. Every month I get 20-25 people who insist on putting the same thing in both the Class box and the Pax box, despite instructions not to do so. This screws up the import into the timing software. The only time you fill in the Pax box is if the Class you pick has (Indexed) as part of the class name. In that case, you put your regular class in the Pax box. Thank you.
Re: Preliminary 6/14/15 Results
Updated results.
