APR two element adjustable - lower element made out of aluminum (to avoid cracking under at high speeds), higher element made out of carbon fiber with a gurney flap at the end
APR aluminum mounts
Custom aluminum mounts that put it as high as the limits if SCCA rulebook allow
Lightweight trunklid (7.8 lbs with 3 brake light and hardware)
Two metal inserts to fill the gap - when you want to drive around without the wing
