1999 Mazda Miata - $5500
Max Hayter
Car#: 31
Post by Max Hayter »
Only 73,300 miles - located in Mission Viejo
Contact me at max.hayter @ gmail dot com
This is a fairly hard to find PEP package car which includes :
Power windows
Power door locks
Power antenna
Cruise Control
Windblocker
Air conditioning (works great)
5 speed transmission
Torsen differential
I spent a long time finding this car. It is in spectacular condition and I have upgraded it with the following :
Pro PartsUSA Koni Race shocks in the front with 500lb springs
Koni Sport shocks in the rear with ISC custom top hats (spring locator added) and 300lb springs
Advanti Storm S1 15x8 wheels with new Dunlop 205/50/15 DZ102 tires (I have the original wheels which will be included in the sale)
Racing Beat front sway bay with HD mounts
Roadster Sport cat back
Aftermarket header with O2 extenders to midpipe cat (no CELs)
99 Sport Front Lip
Alpine H/U with Bluetooth
White gauges from the 2002+ model
In addition, the following maintenance items have been done in the last 18 months :
Timing Belt/Water Pump
Radiator
Brake Master Cylinder
Rear O2 sensor
PCV Valve
New front rotors
Hawk HPS (front) and HP+ (rear) pads (still in boxes unopened)
New Exedy Clutch
Newish top with rear glass. No holes.
New head!!! The car was consuming oil, and it was determined to be the valves. I had a very low mileage head sent out for reconditioning and then installed by Stan. The bottom end looked fantastic, so essentially it's like a new engine now and the oil consumption issue is fixed.
Issues :
Well, none really other than it has a salvage title. The car was hit on the drivers side wheel and required a new wheel, shock, upper control arm and fender (plus associated painting). No inner structure was damaged and the car was professionally repaired. Stan and I have gone over the car and we find no evidence of additional damage. The car aligns perfectly straight. The price reflects the salvage title.
I looked for six months to find a NB in this good a condition... it's very rare to find one this nice.
It just passed smog and is registered until March 2017.
~Max H.
Gearhead's Garage/FRSport
#31 SSC
Re: 1999 Mazda Miata - $5500
Can you fit two sets of golf clubs and a wife in the trunk?
Max Hayter
Car#: 31
Depends on the size of the wife.
~Max H.
#31 SSC
Max Hayter
Car#: 31
SOLD!!!
~Max H.
#31 SSC
I think that's the fasted posted to sold car on the Forum. Ever!
Steve... this Miata ought to fit your requirements...
Wiggy
Post by Wiggy »
Only asking $5000, firm. Car has only 76,800 miles. I have not been autoxing this Miata. I'm co-driving a '93 Miata in CSP when I can still get out to events. Just driving to work once in a while.
Located in Phoenix AZ. I can deliver if you buy me a plane ticket home.
Thanks very much.
