Hello Everyone,
I am brand new to the sport. I did a practice last month at Fontana and my first championship at El Toro on 3/20.
I have a 2010 PHRT and just installed a new set of tires. I'm running C Street and I would like to improve the camber as much as I can.
I live in Manhattan Beach and I very much like 1) advice on how the camber setting for the car (I'm going to be using the car for cancer fundraising, so I expect many novices will be driving it along with myself, 2) a mechanic or shop I can work with to get the settings correct.
Thanks in advance!
Robert
						Miata Mechanic and Camber Settings
- RobertWarrenHess
 - Car#: 378
- Pete Loney
 - Car#: 777
Re: Miata Mechanic and Camber Settings
West End Alignment is THE place to go close to you.
Near the 110 and the 91 intersection.
2021 Season: 777 ES | 1999 Miata, 10th Anniversary  #3987/7500
- Anthony P.
This
						Pete Loney wrote:West End Alignment is THE place to go close to you.
- RobertWarrenHess
 - Car#: 378
Thank you!
The car is very soft from the factory, but can be upgraded within the Street class rules to somewhat mitigate that.
For a CS MX5, the formula for improvement is pretty well know.
You'll want a set of these shocks which will have the added benefit of lowering the car one inch and getting you more camber.
http://www.good-win-racing.com/Mazda-Pe ... -1374.html
http://www.good-win-racing.com/Mazda-Pe ... -1373.html
Also, you'll want an adjustable rear sway bar (something like this)
http://www.good-win-racing.com/Mazda-Pe ... 1247a.html
You will not believe how much better the car will feel with those two changes.
Of course, you will need to redo the alignment afterwards.
- RobertWarrenHess
 - Car#: 378
Thanks, Max!
