Where is the Sun run order posted?
Mark
Run order posted?
Run order posted?
Mark, 1990 Van Diemen, CM
You can try to make a street car into an autocrosser or you can do a lot less work and make a race car into a great autocrosser
Re: Run order posted?
It's not posted yet Mark. Once we get a little closer to the event and can see the pre-reg numbers, the run order will be calculated and posted. Look for it on Wednesday or Thursday.
Thanks, George.
Typically not posted until Wednesday lately, because so many people now wait to pre-register. And likely there will be changes on Saturday. I do, however, try to maintain the rotation, so it you were in 3rd group last event, you will be in the afternoon session this time. And if you were last at the previous event you will be in the morning session this time. The goal is to try to have reasonably balanced work and run groups. Not as easy as it sounds.FFwizard wrote:Where is the Sun run order posted?
Mark
Preliminary Run Order
Subject to change if entries change significantly.
