Dual Adjustables
Dual Adjustables
Okay, my lesson for the week is to try and figure out exactly what dual adjustables are and why you'd want them instead of regular shocks. So I get that DAs give you two different damping levels to choose from, but I have a couple questions:
Can you set both levels manually, so you'd have one that's pretty stiff for autox, and one that's more compliant for the street?
I've looked pretty hard online, but haven't seen DAs offered (seen multi-adjust, but not dual). Are they something that has to be custom made?
What's the relative price difference between a good set of regular dampers and a set of DAs?
Is there anything else I need to consider?
- Christine Grice
- Car#: 17
Re: Dual Adjustables
Ok, lets start here:
Single adjustable shock: Adjust rebound (with a range of settings from soft to stiff), typical adjustment is on the top or bottom of the shock.
Double adjustable: Adjust rebound and compression seperatly
"The category, double adjustable, comes from the fact that the compression and rebound damping is adjusted externally instead of removing the damper from the car. The compression adjuster is located on the remote reservoir. The rebound adjuster is located in the eyelet at the base of the shaft. The main valving, located inside the damper, may also be altered in a matter of minutes, by removing the damper from the car."
qutoed from: http://www.naake.com/Penskeadjustable.html" onclick="window.open(this.href);return false;
Triple adjustable: Adjust high and low speed rebound, and compression. (I think, need to double check)
High and Low speed compression
- Christine Grice
- Car#: 17
Oops, I can never keep it straight. High and Low speed compression.
Anyway, the point is, its not an adjustment between two "settings" its the ability to adjust an aspect of the shock. A single adjustable shock is simple and easy, only one knob to turn. But that knob might have 8 settings ranging from soft -> stiff.
A double adjustable shock allows for a lot more setting combinations but if your not careful you can really screw stuff up. And if you have trouble with doubles, then just forget triples and so on.
(Marshall needs to chime in here somewhere, he is my reference for most things suspension)
For most people? To confuse themselves and screw up a setup to make the car "feel" faster. Can be useful in certain cases, but least confusing way to go is to just have a good set of dampers valved for the springs you'll have on the car and use other methods to effect handling.Kurt Rahn wrote:figure out exactly what dual adjustables are and why you'd want them instead of regular shocks
Last edited by Aaron Goldsmith on Thu Nov 06, 2008 2:24 pm, edited 1 time in total.
- Christine Grice
- Car#: 17
Some good basic reading
Shock tuning guide written by Bob Tunnell: http://www.bimmerhaus.com/tech/shocktuningTN.html" onclick="window.open(this.href);return false;
Simple -(very cheap and crappy) single adjustable example: http://www.shockwarehouse.com/site/agx.cfm" onclick="window.open(this.href);return false;
Koni's North America Website: http://www.koniracing.com/autocross.cfm" onclick="window.open(this.href);return false;
Koni's guide to autocross setup: http://www.koniracing.com/autocrosstune.cfm" onclick="window.open(this.href);return false;
I agree, I was happiest with my WRX after I bought the non-externally adjustable Progress coilovers that Josh Sortor (2005 Champ) had already done the development work on. It was nice having one less tuning variable, and I was able to adjust handling with alignment and tire pressures.Aaron Goldsmith wrote: but least confusing way to go is to bust have a good set of dampers valved for the springs you'll have on the car and use other methods to effect handling.
Sweet. Thanks, guys! Glad I asked.
The need for adjustables can vary by car too. My truck handled very different from concrete to asphalt to that crap we run on in San Diego. So I dropped my nice non-adjustables for some cheap single adjustables (many SA adjust compression and rebound at the same time btw). It made a large difference to tune the truck at each venue. I out them on all 4 corners, but could have gotten away with just the rears.
I would think stock class cars, being so reliant on shocks only to tune suspension it might make sense to do as I described above. Prepared cars get a lot less solely out of the shocks, so a fixed tune on the shock may be less of a determent, assuming that fixed tune is right.
- Mike Simanyi
- Former Club Chair
- Car#: 6
I will personally never again run single adjustable or non-adjustable shocks. Call me an elitist bullet train-detracting chicken-caging snob.
You're a tweaker - you need knobsMike Simanyi wrote:I will personally never again run single adjustable or non-adjustable shocks. Call me an elitist bullet train-detracting chicken-caging snob.
At least he isn't a knob.Max Hayter wrote:You're a tweaker - you need knobsMike Simanyi wrote:I will personally never again run single adjustable or non-adjustable shocks. Call me an elitist bullet train-detracting chicken-caging snob.
The Konis on set just like they were when I first dialed them in with Toby's help. Changed only to save my back on the trip to and from Atwater. I'd rather adjust tire pressures.
One point to keep in mind, adding adjustability into a suspension is basically a waste of money unless you actually adjust things. The more often you test and adjust, the more you get your money back in better performance. The classic bad example is the Viper GTS Coupe driver who pays five figures for Penske 8760 quad adjustable shocks and then asks Erik Messley to, "Set them for the best handling on all the race tracks I'll go to" when the guy comes to pick up the car to drive it home.
I'm not 100% in agreement with that. The adjusters still perform an important part of the overall valving even if you don't adjust them constantly.John Coffey wrote:One point to keep in mind, adding adjustability into a suspension is basically a waste of money unless you actually adjust things. The more often you test and adjust, the more you get your money back in better performance. The classic bad example is the Viper GTS Coupe driver who pays five figures for Penske 8760 quad adjustable shocks and then asks Erik Messley to, "Set them for the best handling on all the race tracks I'll go to" when the guy comes to pick up the car to drive it home.
