CSP tougher than BSP.
Right. Think about it. A better suspensioned, higher HP & tq., nearly the same weight (+100 lbs?) than my car, the S2000, gets SLAUGHTERED by the Evo, and BSP has a lower PAX?!
RR is smoking crack (sorry Rick, I know you read this board, but you got this one wrong). Make CSP higher, in relation to AM, but put it ahead, and that far ahead of BSP? No. That close to ASP? No. And 0.003 behind DP?! I run the same engine as I have now (not even bother to up by 30-50 hp by going to a full-blown DP motor), I put in a roll bar, I run nearly the same weight, except I rearrange it in a MAJOR way (to my benefit) I run SLICKS, and I only have to run 0.18 on a 60 SEC. COURSE faster to beat my CSP PAX???!!! Rick, you can't be serious.
Look at "best of breed". And ASP? Did you not look @ Ken's results this year here?! The totally non-Corvette friendly East course @ HPT?! I know he didn't come out that much, but please - you've got a real good opportunity here in CalClub, Rick; the best BSP driver/car in the country, the best ASP driver/car in the country, then take a look how they do against a top CSP driver/car (They go faster, Rick. And in Ken's case, wayyy faster) - it's real simple.
(not to mention BS, CS and top performers in AS and STU).
Got this one wrong.
