John Williams Contact Info
Hey, I need John. Anybody got his contact info.
I want to machine my top mounts. I think what I have planned is pretty simple. I considered doing it myself, but a machine shop would be a much better plan.
Giovanni Jaramillo
Re: John Williams Contact Info
Post by Giovanni Jaramillo »
You've got a PM.
Car#: 194
Post by Jonathan Lugod »
Steve Ekstrand wrote:Hey, I need John. Anybody got his contact info.
you want room for the shock body to fit huh...
be aware of bottoming out the shock valving itself.
Jon, these are the extended hats so I think I'm well safe with bottoming out the shock shaft. I just need about 7mm's of extra shock body clearance and I think that will eliminate the body striking the spring locator lip as the first thing that hits under compression and make it instead the control arm.
Note that that spring locator lip on the Ground Control tops is like 3x the length down from the top that the "stock" height skunk2 tops are. And they are smaller in diameter. So, I want to cut down the ring to the skunk length and then ever so slightly bore it out a touch.
I need to compare the stock control arm with the skunk2 and see how much travel I might be losing with the aftermarket piece.
On a separate issue.... I have a right side bind I can't identify. I can swing my left side front (without spring/shock) up and down freely with my hand. I need a jack on the right side. :(
Car#: 194
when was the last time you relubed your bushings? ;)
The bushings are a year old.
Car#: 194
are they polyurethane? if they are they are probably in need of maintenance. Polys usually need to be relubed often. I do mine once or twice every 6 months.
They are Poly's.
Jeff Wong
Car#: 146
Post by Jeff Wong »
Steve Ekstrand wrote:They are Poly's.
Hey Steve, if it makes you feel any better, K-Mo probably hasn't lubed his bushings since Rhoades installed them in 04 or 05. :gpower:
Jeff Wong
1994 Honda Civic- STS
ProParts USA
Like Us on Facebook
Jason Flores
Car#: 886
Post by Jason Flores »
Make that 02/03!!! why do u think the car rotates? it doesnt compress it binds and goes!!!!
Jeff Wong
Car#: 146
Post by Jeff Wong »
You are right! When we built the shocks it was back in 06/03 and they haven't been touched.
Boy that kid K-mo is old skool, he was really one of the original Lemmings :thumbup:
Jeff Wong
ProParts USA
Like Us on Facebook
Jason Rhoades
Post by Jason Rhoades »
Jeff Wong wrote:
Jason Flores wrote:
Jeff Wong wrote: Hey Steve, if it makes you feel any better, K-Mo probably hasn't lubed his bushings since Rhoades installed them in 04 or 05. :gpower:
At the time (late '02 early '03) we would've built an '88 Std Civic if we could have found one for a reasonable price. I test drove a couple and they were all really awful. :barf:
The springs/shocks went in in '03 (same rates today as then), but we didn't get around to bushings (or the exhaust, or the fresh motor, or the big swaybar, or the 7.5" wheels, or the ".etc" wing) until '04. Ken won in '03 with a right trailing arm bushing that was completely gonzo. He won again in '05 with a sorted car, but a pretty severe tire disadvantage. This year, there is no tire disadvantage.
Those ProParts Konis are still kicking major ass in their 6th consecutive season on Ken's car, after probably 1000+ autocross runs, tens of thousands of street miles, even a couple track days. They also did the shocks on my 240sx, which kicked butt. It's no wonder I keep going back to them... :thumbup:
Steve, I'd check the torque on your control arm bolts. One or more of them are probably overtightened, pinching the bushing and causing the apparent bind.
