Where should I mount the Oil Temp sensor?
Christos Adam
Car#: 550
Post by Christos Adam »
Hi guys
I got an oil temp gauge which came with an oil temp probe. Where should I mount this?
The car has an oil cooler, so I was wondering is this should be plugged
a) Before the oil cooler
b) After the oil cooler
c) At the oil pan close to the draining hole
Chris
Randy Chase
Car#: 98
Re: Where should I mount the Oil Temp sensor?
Post by Randy Chase »
Sandwich plate for the filter?
Post by Marshall Grice »
I think Randy has the right idea. Ideally you'd put a sensor in all of those places but the most useful is the temp of the oil right before it goes into the engine/bearings.
Christos Adam
Car#: 550
Thanks Randy and Marshall.
From what I recall I have the remote oil filter after the oil cooler (thinking that it's nice to filter everything before goes back in the engine), so that's the temperature of the oil right before it goes into the engine/bearings.
Now I need to make sure there is space in my engine bay and order the Sandwich plate...
