Championship Events
Arthur Grant
- Car#: 314
Championship Events
Looking at the result sheet it shows we have completed 8 of 12 events, however there are 6 more championships on the schedule? Doesn't the season run January to December? Are there two events in the remaining 6 that don't count? Inquiring minds want to know.
- Christine Grice
- Car#: 17
Re: Championship Events
Nope, not nearly that complicated... I use an excel spreadsheet to calculate the points. I built in the capacity for 13 events, you just can't see the last one cause I hide it. So if we end up running a 14th event, I'll just need to add that to the spreadsheet. ;)Arthur Grant wrote:Looking at the result sheet it shows we have completed 8 of 12 events, however there are 6 more championships on the schedule? Doesn't the season run January to December? Are there two events in the remaining 6 that don't count? Inquiring minds want to know.
The number of events that we drop from the year end points is still controlled by rule 7.6 in our supp regs. Except you run novice, so your number of drops per year is covered in Appendix A.
- Casey Brier
- Car#: 806
what are the total number of events, and number of drops going to be this year?
- Christine Grice
- Car#: 17
Looks like it will be 14 events (based on the current schedule)Casey Brier wrote:what are the total number of events, and number of drops going to be this year?
Which means I have updating to do to my spreadsheet since I only have 3 drops built in right now...APPENDIX D
CSCC Solo Number of Drops Index
Number of Events Number of Drops
1 to 3 ----------0
4 to 6 ----------1
7 to 10--------- 2
11 to 13 -------3
14 to 16 -------4
17 and up -----5
Arthur Grant
- Car#: 314
Thanks Christine. I assume at the end of the year I can drop my DNS and two no entry events. Need to keep all the points I can.
Keep in mind you're running in novice class - per the supplemental regulations, only your six best results count.Arthur Grant wrote:Thanks Christine. I assume at the end of the year I can drop my DNS and two no entry events. Need to keep all the points I can.
Arthur Grant
- Car#: 314
Well there goes my strategy of bludgeoning the points by running more events.Leonard Cachola wrote:Keep in mind you're running in novice class - per the supplemental regulations, only your six best results count.Arthur Grant wrote:Thanks Christine. I assume at the end of the year I can drop my DNS and two no entry events. Need to keep all the points I can.
- Karen Zaterman
- Car#: 134
You can still run more events to get better results... which we are sure you will ;)Arthur Grant wrote:Well there goes my strategy of bludgeoning the points by running more events.Leonard Cachola wrote:Keep in mind you're running in novice class - per the supplemental regulations, only your six best results count.Arthur Grant wrote:Thanks Christine. I assume at the end of the year I can drop my DNS and two no entry events. Need to keep all the points I can.
No, Mako -- you do NOT need to supercharge your new Miata! ...cuz now it's my turn to take it to the track
hmmmm... it is no longer "new" -- is it time to get faster?
Arthur Grant
- Car#: 314
Well my intent is to run all the remaining events, although I question the sanity of running Fontana in August. My hope is to raise my average, but I have found it's hard to match points. As long as I personally get better I will be happy.
Arthur Grant wrote:Well my intent is to run all the remaining events, although I question the sanity of running Fontana in August.
Who is running fontana in August???
