FasTrack News (Solo) - November 2010
Giovanni Jaramillo
Click link --> FasTrack News (Solo) - November 2010
Re: FasTrack News (Solo) - November 2010
Service UnavailableGiovanni Jaramillo wrote:Click link --> FasTrack News (Solo) - November 2010
HTTP Error 503. The service is unavailable.
- EpicFail.jpg (45.27 KiB) Viewed 10915 times
Greg Peng
- Car#: 908
The SCCA website went down a few minutes ago. I was able to see the Fastrack from Gio's link before the site went down.
Giovanni Jaramillo
So that means Kurt fails...BIG TIMEGreg Peng wrote:The SCCA website went down a few minutes ago. I was able to see the Fastrack before it went down.
Greg Peng
- Car#: 908
SCCA fails. :mrt: I'm trying to see the rulebook to see what's changing.
Giovanni Jaramillo
Totally!Greg Peng wrote:SCCA fails.![]()
The things that jumped out where things like BMW M3 (E46, E36) moving from BSP to CSP (along with the Mazda RX-8).Greg Peng wrote:I'm trying to see the rulebook to see what's changing.
The move from BSP to ASP for the Mitsubishi Evolution has been tabled for now.
Something about strut bars for ST cars
But basically this month's Solo section of FasTrack is a LONG one. A nice read
- Michael Smith
- Car#: 21
STREET TOURING
- In light of further member input received since its prior meeting, and per the unanimous recommendation of the STAC, the
SEB has reconsidered its earlier decision and is recommending the following change to the BOD, effective 1/1/2011:
- Delete 14.2.F
- Delete 14.2.F
Greg Peng
- Car#: 908
Looks like the cone penalty assessment is being changed. Instead of a cone touching the box line being OK (non-penalty), it has to touch the inner edge of the line to be OK.
2011
2011
Current“A clearly-visible line around its base will mark the location of each pylon. The inner edge of the line will be used to
describe the outer edge of the pylon base as accurately as possible and this inner edge will be the penalty limit. If
the pylon is upset or totally displaced outside the penalty limit, two seconds will be assessed. At Regional events,
local methods for locating pylons may be used. The diagram provided herein should help clarify situations in which
penalties should and should not be assessed.”
A line two inches wide or two lines two inches apart will describe the
location of each pylon. (If two lines are used the distance between the
inner edge of the inner line to the outside edge of the outer line will be
two inches plus or minus 1/4”.) The inner edge or inner line will be used
to describe the outer edge of the pylon base as accurately as possible
and the outer edge or outer line will be the penalty limit. If the pylon is
assessed.
Greg Peng
- Car#: 908
What is 14.2.F?Michael Smith wrote:STREET TOURING
- Delete 14.2.F
"F. Addition of spoilers, splitters, body kits, rear wings and nonfunctionalMichael Smith wrote:STREET TOURING
- Delete 14.2.F
scoops/vents is allowed."
Oh snap, dumping wings AND spoilers. Everyone come on over to SP+ if you aren't Stock legal in your body.
Someone save their copy and attach it to this thread, haha.
Greg Peng
- Car#: 908
Blah.
10-fastrack-nov-solo.pdf- (187.56 KiB) Downloaded 287 times
Giovanni Jaramillo
So Greg and I are "Kings of FasTrack" this month
- Michael Smith
- Car#: 21
STREET TOURING
- Change 14.2.G to read as follows:
“G. Strut bars (see Section 12) are permitted with all types of suspension, subject to the following constraints:
4. Except for standard parts, no connections to other components are permitted.
Arthur Grant
- Car#: 314
I'm bummed, I think I would have liked to see the Evo's leave BSP.
Giovanni Jaramillo
website is back up so feel free to click on the link in the original post. Though thank Greg for saving his "cached" version of the PDF file.
"Move from ASP to BSP:
MR2 turbo & N/A (’91-’95)
Note: remove N/A from CSP"
Mr. Clements to the NA with a 3sgte courtesy phone.
Two more of the front running HP (Club Racing) cars moved to GP for Solo... But the slower Yaris is left in EP. :unimpressed:
Add the following listing items for Appendix A, GP Limited-Preparation:
“BMW
1600 (’68-’71) - 1574 - 1575 - 13x7 - 1.65/1.38 - 56.5/56.5
Carburetion
Comp. ratio limited to 11.0, valve lift to .450”
Alt. intake manifold #CAM-6618
Toyota
Corolla (’71-’74) - 1588 - 1590 - 15x7 - 1.61/1.42 - 57.9/57.5
Carburetion
Comp. ratio limited to 12.0, valve lift to .450”
“BMW
Carburetion
Toyota
Carburetion
Bye Bye Wings/Spoilers!
So happy!
Edit: Add Splitters into the mix!
Next up will be the introduction of R-compounds... Then it comes full circle.Jeff Wong wrote:Bye Bye Wings/Spoilers!So happy!
- Michael Smith
- Car#: 21
and modified bumpers. anyone have pics of swiss cheese?Jeff Wong wrote:Bye Bye Wings/Spoilers!So happy!
“7.9.2 Displaced or Downed Pylons on Course
A competitor encountering a downed or displaced pylon on course has the option of continuing the run or stopping
as soon as possible, and pointing out the downed or displaced pylon to a course worker. If the competitor stops,
he or she must proceed off course and will then be granted a rerun. However, if the competitor completes the run,
the time will stand.”
Not good for Seb
He has a good eye for those downed/displaced cones!
Not good for Seb
Is this a section we have to follow? Basically means you have to red flag all cars on course as a slow moving car along the outside of the course would almost always be considered a safety hazard. People can often point out down/out cones without impacting following cars.Jeff Wong wrote:“7.9.2 Displaced or Downed Pylons on Course
Not good for SebHe has a good eye for those downed/displaced cones!
- Eric Clements
7.4 tells you how to exit the course after stopping for a down/out cone.
- Michael Palero
- Car#: 18
Jeff Wong wrote: Not good for SebHe has a good eye for those downed/displaced cones!
