The Daily Give Away of everything GoPro makes is continuing:
http://www.goprocamera.com/contest/index.php
GoPro News
GoPro News
Re: GoPro Daily Give Away Promotion, Last Day, I think ?!!
Fixed link that won't assume you've already entered: http://www.goprocamera.com/contest/index.php" onclick="window.open(this.href);return false;
Re: GoPro Daily Give Away Promotion ... Still Going On
Check out all of the cool GoPro stills and frame grabs here: http://www.facebook.com/album.php?aid=1 ... 0043151918" onclick="window.open(this.href);return false;
NEXT WEEK (after Xmas) ... keep you eyes open for a Photo of the Day featuring our KIDS !
Crazy time continuum capture! The way the sensor is scanned froze the rubber band at many points so it looks super long and stretched out.
The up-coming clip-on Monitor that we've all been waiting for:
Arthur Grant
- Car#: 314
Re: GoPro News
I know I should have asked this before, is there a way to adjust the camera for indoor low level light?
Re: GoPro News
No ... but the camera adjusts it's ISO and shutter speed to come up with a proper exposure. The GoPro is not a great low light camera ... yet was chosen to be the up-angle from the rescue capsule of the Chilean Miners ... with one LED light box pointing up.
What is amazing about the GoPro's (Center Weighted default) metering system is that it will ignore bright hi-lights in the angle of view to maintain proper exposure, instead of darkening the overall exposure.
One CAN switch from Center Weighted metering to Spot Metering ... which works well if the camera is in the back of the car, looking out through the windscreen. But when I put it into Spot Meter mode for the Point of View shots from Karen's helmet, it didn't work well because the camera was pointed slightly down ... so that we could see her steering and shifting. The Spot meter was reading the dark dashboard, opening up the exposure so that the it was too bright outside. The more "averaging" Center Weight metering mode would have been a better option after all.
Here's about as low light level a shot as one can expect to get a decent file with noise starting to creep in ... 1/3rd second (camera resting on display case), F3.6, 400 iso:
