FS: 949 Wheels/Hoosier Tires
Sean Goodbody
Four 949 Racing 6UL 15x8" +36mm (4x100) silver wheels with 35 run (40% tread left) 225/45/15 A6's mounted. The wheels have some brake dust residue that didn't come off with a quick rinse, but there is no paint or any other damage to the wheels. A motivated person with some wheel cleaner could make them look new.
$600 ($425 wheels only, $225 tires only)
Four 275/35/15 35 run Hoosier A6's with plenty of tread left.
SOLD
Wheels:
225's:
SOLD
Wheels:
225's:
- 275-2.jpg (460.06 KiB) Viewed 7443 times
Last edited by Sean Goodbody on Wed Aug 24, 2011 10:47 pm, edited 1 time in total.
David Barrish
- Car#: 58
Re: FS: 949 Wheels/Hoosier Tires
Sean,
Please measure the back space of the rim to hub mounting surface. They might fit for my BMW.
Thank you.
David Barrish
Thank you.
David Barrish
- Doug Teulie
- Car#: 99
David Barrish wrote:Sean,
Thank you.
David Barrish
David,
Use my lower chart (from Doug's Scirocco parts book) to calculate back spacing from offset. The upper chart shows the VW A1 wheel numbers. It looks like 8" with ET 35 has a 5.875 backspace. I would need a 19mm - 25mm spacer to run that wheel on my car depending on the tire width.
8" wheels with Greater offset and stretched tires can help the tire clear "some" of the rub points. See the illustration above.
Doug T
David Barrish
- Car#: 58
Doug,
Thank you for the info. I will once again retreat to my mountain longing for a set of rims that does not require a year of peanut butter sandwiches for lunch. Ya, I know, good luck
But now I know what I am looking for, 15X9 with a -19 off set. I have the Turbo flares on my 2002.
David Barrish
David Barrish
David,
Spacers are your friend. If the bolt pattern works, you could achieve that 19 offset with a 17mm spacer.
Hi Sean,
pm sent.
Ira
pm sent.
Ira
Sean Goodbody
275's sold. Wheels/225's still available (David... ;) ).
angel pena
still got the wheels for sale ?
Daniel McClelland
Are these wheels still around?
angel pena
Still have the wheels for sale ?
