FS: 949 Wheels/Hoosier Tires
Sean Goodbody
Post by Sean Goodbody »
Four 949 Racing 6UL 15x8" +36mm (4x100) silver wheels with 35 run (40% tread left) 225/45/15 A6's mounted. The wheels have some brake dust residue that didn't come off with a quick rinse, but there is no paint or any other damage to the wheels. A motivated person with some wheel cleaner could make them look new.
$600 ($425 wheels only, $225 tires only)
Four 275/35/15 35 run Hoosier A6's with plenty of tread left.
SOLD
Wheels:
949 Wheels 15x8-2.jpg (464.87 KiB) Viewed 7440 times
225's:
Last edited by Sean Goodbody on Wed Aug 24, 2011 10:47 pm, edited 1 time in total.
David Barrish
Car#: 58
Re: FS: 949 Wheels/Hoosier Tires
Post by David Barrish »
Sean,
Please measure the back space of the rim to hub mounting surface. They might fit for my BMW.
Thank you.
David Barrish
Doug Teulie
Car#: 99
Post by Doug Teulie »
David Barrish wrote:Sean,
Thank you.
David Barrish
David,
Use my lower chart (from Doug's Scirocco parts book) to calculate back spacing from offset. The upper chart shows the VW A1 wheel numbers. It looks like 8" with ET 35 has a 5.875 backspace. I would need a 19mm - 25mm spacer to run that wheel on my car depending on the tire width.
8" wheels with Greater offset and stretched tires can help the tire clear "some" of the rub points. See the illustration above.
Doug T
David Barrish
Car#: 58
Doug,
Thank you for the info. I will once again retreat to my mountain longing for a set of rims that does not require a year of peanut butter sandwiches for lunch. Ya, I know, good luck
But now I know what I am looking for, 15X9 with a -19 off set. I have the Turbo flares on my 2002.
David Barrish
David,
Spacers are your friend. If the bolt pattern works, you could achieve that 19 offset with a 17mm spacer.
Ira Cruz
Car#: 789
Post by Ira Cruz »
Hi Sean,
pm sent.
Ira
Sean Goodbody
275's sold. Wheels/225's still available (David... ;) ).
angel pena
Post by angel pena »
still got the wheels for sale ?
Daniel McClelland
Post by Daniel McClelland »
Are these wheels still around?
angel pena
Still have the wheels for sale ?
