I had these mounted a couple weeks ago and finally put them on last week.
I thought it was weird that a couple tires had zero inflation - so I inflated them to 35 psi & popped them on.
Of course, I only realized that the tire was leaking AFTER mounting them.
I started backing out the car out of the driveway yesterday & the passenger front tire was flat!
It is losing about 3-4 psi/hour; I finally found the point of the leak(s) this morning while pumping up the tire:
It is leaking @ 2 points (that I can see): the big bubble & about 2" up from there - smaller bubble (residue of said bubble in the pic).
The driver side might also be leaking, but if it is, it is doing so very slowly (possibly 1-2 psi/day).
At this point, I have no clue if it's the rims (just bought them used, I don't think the previous tires were 0 psi, but I never ran them), the tires (just bought from a guy, but they were sitting in his basement 2-3 years), or the mounting (first time I've had them mount tires - rims were off the car when I had it done).
