How I can check if my engine mounts are bad? (Mazda Miata)
Christos Adam
Car#: 550
Post by Christos Adam »
Hi guys (and gals)
I have the impression that at Saturday's GRA event in one of the 20 laps I broke one of my engine mounts (or maybe two - but definitely not three 8-) ).
Is there a relatively easy way to test that?
I just noticed that when the engine turns off it vibrates a bit more than it used to...nothing dramatic but I can definitely feel something different...
I currently have the Mazdaspeed mounts on my car - which I believe are a bit stiffer but not up to the new torque levels of the engine. I guess the constant downshifting/upshifting during the practice didn't help either }:)
Chris
Casey Brier
Car#: 806
Re: How I can check if my engine mounts are bad? (Mazda Miata)
Post by Casey Brier »
there is always the e-brake trick.
pull the e-brake up, (and/or push on the brakes) and with the car in gear try to move the car, meaning let the clutch out about half way rather quickly and then push it back in (so you dont stall). your looking for how much the engine moves. (takes two people). some movment is ok of course, but if it looks like its way more then just a little bit or it clunks thats a pretty good sign.
Here is a video of a guy doing what I said. http://www.youtube.com/watch?v=8pJuY4UO ... re=related" onclick="window.open(this.href);return false;
or you can just rev it up....
http://www.youtube.com/watch?v=FrK8-fd9cN8" onclick="window.open(this.href);return false;
Hope that helps.
Casey Brier wrote:there is always the e-brake trick.
Hope that helps.
What he said. I've heard we have one of the best engine mount inspectors in the country right here in our region. Maybe you could give Renee a call for help on this. :thumbup:
Casey Brier
Car#: 806
without putting too much thought into it, I belive you do the soame thing in reverse gear and it will test the other side. (it twist the engine in the other direction...... I think)
Casey Brier wrote:without putting too much thought into it, I belive you do the soame thing in reverse gear and it will test the other side. (it twist the engine in the other direction...... I think)
You might want to think about that one just a little longer...
:lol:
:lol:
I agree with Casey. The torque applied to the engine is derived from the locked up drive shaft which obviously reverses when the car is in reverse. Am I missing something?
Last edited by George Schilling on Tue May 05, 2009 10:03 am, edited 1 time in total.
Car#: 194
Post by Jonathan Lugod »
8-)
Last edited by Jonathan Lugod on Tue May 05, 2009 10:02 am, edited 1 time in total.
you might want to draw a freebody diagram real quick...
:D
for the record the engine will rock the other direction in reverse when you release the clutch.
Nevermind, Marshall, George and Casey are right.
(youtube is quicker than a free body diagram)
http://www.youtube.com/watch?v=uKnQQoORbtk" onclick="window.open(this.href);return false;
Christine Berry wrote:Nevermind, Marshall, George and Casey are right.
Yeaaaa. :gpower:
I'm almost always "right" but it's nice to finally have someone acknowledge it. :lol:
How does the engine change direction THAT quickly when you go into reverse ?
:D
Tom Denham
Car#: 237
Post by Tom Denham »
Mako Koiwai wrote:How does the engine change direction THAT quickly when you go into reverse ?
:D
In a Miata??? Make sure your hamster has new tennis shoes. :shock:
Christos Adam
Car#: 550
Hey guys, could you please watch the video below and let me know what do you think?
http://s15.photobucket.com/albums/a361/ ... V00867.flv" onclick="window.open(this.href);return false;
It seems to me that at least the driver side mount is shoot (which can be observed when I put reverse - at the begging of the video) :barf:
You can also hear the noise that I was talking about n the previous posts when I shut the engine off.
I used to just put a jack under the engine and jack it up a bit and see if the mount separates. Of course that was on a 240Z where you could actually see the ground through the engine compartment and the mounts were not obscured by anything at all.....
Let Bill Schenker drive it. If its not broke yet, it will be.
Christos Adam
Car#: 550
Steve Ekstrand wrote:Let Bill Schenker drive it. If its not broke yet, it will be.
LOL, yeah I need to ask Bill he will know...
Casey Brier
Car#: 806
looks to me that is the right side mount that is broke. (lifting to much).
when in forward gear all looks fine.
Casey Brier wrote:looks to me that is the right side mount that is broke. (lifting to much).
Broken or loose.
I concur. Should be an easy change out on that side.
Just have someone ride the clutch in reverse and you'll get that extra arm room you need to change it.
