Hi board mod's...
This afternoon I started getting this message at the top of every screen. Don't understand the details (my computer clock is correct), but I've never seen it before. Though you might like to know if your not seeing it.
Feel free to delete this post once fixed. Thanks
Craig
Error message:
[phpBB Debug] PHP Notice: in file /viewtopic.php on line 981: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone.
[phpBB Debug] PHP Notice: in file /viewtopic.php on line 981: getdate(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone.
Board Moderators: Error message of some type
Re: Board Moderators: Error message of some type
I'm getting it as well.
looks like our server host upgraded our PHP install and screwed up the php.ini file.
...not that i know who our host is or how to fix it.
- Christine Grice
- Car#: 17
It is being worked.
Thanks!!! :heyes:
not seeing the error today.
Feel free to delete this thread.
