Looking to buy a set of 18x8 wheels:
50mm offset,
67.1mm center bore,
5x4.5 (114.3mm) bolt pattern.
I believe these are the specs, pulled from the internet. I haven't had a chance to measure them yet, just got the car. These are stock size Rx8 wheels. If you have anything laying around I'm interested.
Freddie.
WTB: 18x8 wheels (Rx-8 size)
- Fred Sullivan
- Car#: 502
- Jeff Stuart
Re: WTB: 18x8 wheels (Rx-8 size)
PM'd you!
- Marc Leininger
- Car#: 411
Interesting item on their web site:Marc Leininger wrote:http://www.wedswheelsna.com/weds/wedssport/
New! Closed-End Racing Lug Nut(Aluminum Type)
...provides an average 52% weight reduction compared to conventional steel lug nuts. (only weigh 22grams vs. 44grams avg steel per their own claims)
- Not recommend using... actual competition use.
Racing Lug nut... not for actual competition use!
Wow you saved less than 1/5 lbs per corner, but then you can't go race!
- Fred Sullivan
- Car#: 502
Hey Jeff, I Pm'd you about the wheels. I am interested, but not sure if you got it.
Marc, if the wheels fall through with Jeff do I order them through you or one of your distributors?
I have 18x8 Rota wheels in black with toyo tires on them, two should have tires replaced. They are factory RX8 offset within 1/4 inch if not exact. Very light wheels. Give me a call at 714-448 one seven two four for more details.
Steve O'Blenes
Steve O'Blenes
- Marc Leininger
- Car#: 411
Hi Fred,
If you interested in getting the wheels from me let me know, I'm sure we can get you taken care of one way or another.
Marc
Marc
- Fred Sullivan
- Car#: 502
Thanks for checking in Marc, I picked up a set of wheels.
