Gary said he's never seen this. I'm guessing a ceramic CAT element pulverized itself?
What's Wrong With This Z06 ?!
Preceded by a big cloud of smoke, while banging on the rev limiter in 2nd ... but car seems to be running fine. Slight 2nd puff of smoke and then nothing. Left back side of car is covered is white powder.
- Z06 exhaust.jpg (218.14 KiB) Viewed 12732 times
Re: What's Wrong With This Z06 ?!
Left rear is covered with white powder:
- PowderOnLeft.jpg (149.9 KiB) Viewed 12726 times
- Glenn Duensing
- Car#: 28
- Location: Relaxin' and chillin' on the third rock from the Sun.
John DeLorean says it's nothing, just left-over residue from following the white lines
Pillsbury Dough Boy RIP
Raise the car & bang on the dr side cat w/ a dead blow mallet. If you hear tinkle, tinkle cat matrix is toast. You may not hear anything if all the matrix is gone. Also rev car while tapping cat (if you can manage to do this) & see if any pieces fly out the back.
How many miles on it? Year?
Clean it up (except the white powder) & remove all evidence of spirited driving. Drive to dealer. May be covered under emissions extended warranty.
You might go to where the white puff happened & CSI it for debris.
Here's a plug of ceramic CAT cat that blew out of a 275 wheel horse power Mini. But what we saw blow out of the Vette was a BIG cloud of white "smoke," which turns out to probably be powder.
The Z06 in question use to have Nitros ... wonder if that contributed to the CAT's early demise?
They should not run the engine until they check the cats. Broken up catalyst can actually work it's way UP into the engine if the vibrations are just right.
Nitrous can cause crazy exhaust temperature swings. I imagine the cat wouldn't like that much.
- Chuck Fowler
- Club: Team Blew
- Car#: 299
if that's the car i'm thinking of, and considering who installed the NOS system, the current owner might ask the installer to replace the CATMako Koiwai wrote:The Z06 in question use to have Nitros ... wonder if that contributed to the CAT's early demise?
Nicole Wong
- Car#: 46
Why are we dancing around who owns this car?? I only know 1 vette with that smiley face sticker on itChuck Fowler wrote:if that's the car i'm thinking of, and considering who installed the NOS system, the current owner might ask the installer to replace the CATMako Koiwai wrote:The Z06 in question use to have Nitros ... wonder if that contributed to the CAT's early demise?
- Ron Flaherty
This bothers me, please explain!!!!!Will Kalman wrote:They should not run the engine until they check the cats. Broken up catalyst can actually work it's way UP into the engine if the vibrations are just right.
Mako nailed the prob on-site "looks like the cat exploded" checking the cel code showed we had lost the DS cat....just need to find out why, motor may have gone way lean riding the limiter???
thanks for all the input
(gotta pull my smiley sticker to hide from Nicole)
It is a Corvette, they do this. :unimpressed: The T1 guys killed them so often they got the Club Racing rules changed to allow them to come off. I replaced them twice on my C4. Small cats very close to the header=fail. Replace them now and you should be good for a few years.Ron Flaherty wrote:This bothers me, please explain!!!!!Will Kalman wrote:They should not run the engine until they check the cats. Broken up catalyst can actually work it's way UP into the engine if the vibrations are just right.
Last edited by Jason Isley BS RX8 on Mon Jun 22, 2009 8:03 pm, edited 1 time in total.
- Tom Berry
- Car#: 72
If any help.. I have a couple of 99 Vette cats that have less than 25 k on them.
I think the Z uses a different one... My dad got some take offs from a 00' non Z and they were different dia than his.Tom Berry wrote:If any help.. I have a couple of 99 Vette cats that have less than 25 k on them.
- Tom Berry
- Car#: 72
So that would fall under the "No help" catagory
- Chad Stubblefield
- Club: Team Blew
- Car#: 877
thats a good thing
you want the cat vaporized
your in stock class
Is it legal to not replace a vaporized cat?
your in stock class
Should have removed that tattle tale Smilie!
- Ron Flaherty
Thanks everyone for your input on my jinxed Z06.!!!!!!
dealer warranty work will not work, (NOS install) Looking for CATS...I can get high flow, not legal for $100.00, stock legal, $450.00???? ASP is looking very nice
Or you could sell the car and buy an old Miata for $450.Ron Flaherty wrote:Thanks everyone for your input on my jinxed Z06.!!!!!!
dealer warranty work will not work, (NOS install) Looking for CATS...I can get high flow, not legal for $100.00, stock legal, $450.00???? ASP is looking very nice![]()
- Chuck Fowler
- Club: Team Blew
- Car#: 299
if were going to spend their $$, i vote for the MGBGeorge Schilling wrote:Or you could sell the car and buy an old Miata for $450.Ron Flaherty wrote:Thanks everyone for your input on my jinxed Z06.!!!!!!
viewtopic.php?f=8&t=2370
But they're used to cars that start when you turn the key.Chuck Fowler wrote:if were going to spend their $$, i vote for the MGBGeorge Schilling wrote:Or you could sell the car and buy an old Miata for $450.Ron Flaherty wrote:Thanks everyone for your input on my jinxed Z06.!!!!!!
- Steve Abbott
- Car#: 48
High flow cats probably will not pass the smog test. They don't clean the air as good as the stock ones.Ron Flaherty wrote:Thanks everyone for your input on my jinxed Z06.!!!!!!
Steve A.
But they want a competitive car. Like mine.Chuck Fowler wrote:if were going to spend their $$, i vote for the MGBGeorge Schilling wrote:Or you could sell the car and buy an old Miata for $450.Ron Flaherty wrote:Thanks everyone for your input on my jinxed Z06.!!!!!!
viewtopic.php?f=8&t=978&start=0&st=0&sk=t&sd=a" onclick="window.open(this.href);return false;
